Engine Trouble
Jayamashey
Need some help with an engine problem.
I completed a B16A SIR2 swap in the fall. Everything was running great until the weekend.
I drove it about 30 miles (50km) and it ran fine. Then i washed it and sprayed the engine bay down just with the hose. Then some guy came over and test drove it by himself (I am selling).
After he got back I started it and the engine is now studdering (especially in lower RPM). It feels like its misfiring and definately underpowered, but I am not getting any codes. When I accelerate in neutral and hit 4000-5000 RPM it makes a terrible noise (almost like loose heatshields), but over is better. It seems to shake/shudder alot in the lower RPMs when gas is given. Idle sounds OK but is a little more rough then normal but doen't have the shudder.
Any ideas?
BTW: Plugs, wires, dizzy, timing belt, O2 - are all 3 months old and worked well.
Thanks, but that was the first thing i check and it was dry.
Also car almost bogs to a stall on idle . But runs better in the higher RPMs (over 5000).
take your spark plug wires out off the head and see if you got water in the spark plug holes mine done the same thing when i washed my engine hope this helps
