Engine Tuning
Discussion in 'General Tech and Maintenance' started by vtecsir1, Jan 7, 2003.
  1. vtecsir1
    vtecsir1 Senior Member
    Orlando, FL
    I installed a vx motor into my civic to get me by, not my choice of motors but i needed transportation anyways i installed this motor and its running real rough and im not sure what it might be. the motor is shaking a decent amount and sputtering, i checked the sensors and they are plugged in correctly. i was thinking maybe timing. anyone have the same problems? any info. thank you.
  2. asmallsol
    asmallsol Super Moderator
    Houghton/Livonia Michigan
    Is it throwing any codes?
  3. vtecsir1
    Orlando, FL
    didnt check, forgot about that. thanks under the carpet there is a light right that flashes?
  4. LIhybrid
    LIhybrid Junior Member
    Make sure you hooked up your spark plug wires in the right firing order. Make sure the plugs are good and the wires are connected properly.
  5. cws13
    cws13 Senior Member
    Athens,GA
    was that the motor that came with the car? You may be running the wrong ECU. THe VX has unique parameters to the other civic models.
  6. vtecsir1
    Orlando, FL
    my car is a cx, still running the stock cx ecu i was hoping i would get lucky and it would work, guess not. going to pick up the ecu this weekend.
