Engine whine when reving
Discussion in 'General Tech and Maintenance' started by MadMaXXX, Jan 23, 2007.
  1. MadMaXXX
    MadMaXXX Mad Man
    USA
    hey guys
    Recently i noticed, on my 96 civic, that there is a whine comming from the timing belt area, but only after i rev the engine or when the RPMs drop after reving
    is this normal, or is my timing belt or something else going?
  2. jeffsciv23
    jeffsciv23 Senior Member
    Wa
    usually when you hear a whining sound it is the tranny but it could be something different in your case. have you messed with anythign on that side of the motor recently? any of the belts too tight?
  3. MadMaXXX
    MadMaXXX Mad Man
    USA
    nope didnt do anything to it
    so if its the tranny im fine?
  4. 801CRX
    801CRX Got Rice?
    UTAH
    Check your altenator pulley alignment
    And then lube your belt
    See if any of this works.
  5. MadMaXXX
    MadMaXXX Mad Man
    USA
    is there a specific type of lube to use?
    thanks
  6. 801CRX
    801CRX Got Rice?
    UTAH
    Ok your not going to believe me but trust me!!!
    Take a bar of soap (yes regular hand soap) and hold it to both outside edges of the belt while its spinning just enough to evenly cover the edges...........be carefull.
    Hopefully it will fix the noise?
  7. 801CRX
    801CRX Got Rice?
    UTAH
    Why spend .99 cents, when you can do it for free with soap. Then you could go to McDonalds dollar menu and get a burger.
    LOL
    Dollar Menu...........FTW!
  8. MadMaXXX
    MadMaXXX Mad Man
    USA
    alright i will try it this weekend
    if successful, i will go get a big Mac ;)
    thanks again
  9. 801CRX
    801CRX Got Rice?
    UTAH
    If successful let me know on here!
    Oh and enjoy your Big Mack!!!
  10. turbo sol
    turbo sol I need some ligaments!!!
    laurel, montucky (ten minutes out of billings)
  11. 801CRX
    801CRX Got Rice?
    UTAH
    Dude thats old I posted that like weeks ago!!! check the LOUNGE
    And dont thread jack!!!
