So you're running the stock F22B1 engine right now? Or, as your name suggests, are you running an H22?
If you're running the F22, VTEC engages at around 2700 rpm. You won't feel it or hear it, since single-cam VTEC is pretty much worthless (designed only for fuel economy and existing on the intake valves only).
If it's the H22, then as stated above, VTEC engages at 5200 rpm, and you should most definitely feel it.
