Enjo mounts
civic_types
Does Enjo make mounts for a B-series swap into a 92-95 civic ??
yeah i got them on my car
^i blew this motor up :(
Good that's a big motor !!
Thanks alot for the pics, much appreciated
just finished a B16A swap in my 93 cx. Just need the driver's side mount and bracket.
Crunching #'s to see if I should just go out and buy Enjo's now instead of later replacing OEM's that I would order tomorrow.?!?!
Even if i had a stock b16 in my car i would upgrade the mounts to racing ones when i put it in cause they are stronger and may help your times a little bit
i have a fast question about mounts ,well im building my ls/vtec right now and my set up is a b16 vtec head ab16 tranny and b18 ls block i herd that i should use si mounts for the tranny but can anyone tell me what mounts i should buy and if i have to buy seperate mounts?
