Erratic Idle, Please Help!!!!
Discussion in 'General Tech and Maintenance' started by ruacura91, Jun 7, 2004.
  1. ruacura91
    ruacura91 Junior Member
    I have a 1991 Acura Integra with a 5 speed non-vtec engine.
    I have been having idling problems where starting up the idle is high then when i start driving and stop the idling is still high and starts to fluctuate from about 800 RPM's to 1700 RPM's. It seems that when i turn on the AC the idling problem stops but still stays higher, like about 1100 RPM's, but if I leave on the AC in about 20 seconds the RPM's start climbing and then will do the RPM fluctuate just like when i left it off. I dont know what to do, I have tried to check the IAC Valve and it clicks if voltage is applied, the ohms are about 12.3, which is supposed to be normal and there is plenty of voltage when the plug is tested. Could cleaning the IACV be the problem, if so how do i clean it and if this couldnt be the problem then what could it be. I heard it could possible be the ECU computer. PLEASE ANYBODY HELP ME!!!!
    I'm trying to sell the car but want to fix the problem before I sell it.
    Thanks
    Ryan
  2. tab
    tab Super Moderator
    Aberdeen, Washington State
    there's an article on this subject, did you read it?
  3. Riceburner
    Riceburner Senior Member
    Tennessee
    sounds like a vacum leak...
  4. JDMG2i
    JDMG2i Junior Member
    Cover your throttle body with your hand all the way and if it stays on and idols right then you have a leak . If your car shuts off then its not a leak look in your trottle body there should be 2 holes or 1 in it if there are 2 cover the top 1 of then up if it idol right then its then its the sensor on the back of you manifold I think its called the idol air control valve and if you cover the bottom one and it idols right then its the sensor right under the throttle body. let me know if I help you because I had the same problem And thats how I fixed it. I dont think you can clean IACV if its messed up then you need a new one.
