error code P0410 2nd air injection
Discussion in 's2000' started by phonedrn8, Sep 8, 2009.
  1. phonedrn8
    phonedrn8 New Member
    Las Vegas
    tried to get 03 to pass smog but got a error code P0410 Secondary Air injection System, what can cause it?
    i cam home check all cables and code but light wont go out
    Any help will be
  2. Ronny Cage
    Ronny Cage DaughterTestedMomApproved
    south jersey
    do you have aftermarket intake? also check your tubing coming into the intake/stock intake box. especially on the stock intake box its comming to pinch the one 1/4 hose and pop that code. I popped that code after doing a serpentine belt on my buddy's s2000, didnt put the solid black cover on correctly and popped that code, I hear this code pops for the charcoal canister as well... i'll look into it more for you but that off the top of my head, good luck!
  3. phonedrn8
    Las Vegas
    p0410got it fix airpump replaced
    p0411 replaced Vac tube hose
    stillerror code incorrect flow come to find out kinked airflow hose lower return all good now
