ERROR CODE P1162 : Air/Fuel Ratio (A/F) Sensor (Sensor 1) Slow Response
GreenMcNasty
I Got this code on my 2000 Honda Civic HX. Is this the O2 sensor? And if it is, which one? Pre or post cat?
Checked my alldata, p1162 is slow responce for o2 metering, sensor 1
which you knew
it is your o2 sensor
Pre cat
just replace it, but use a good quality replacement such as bosch or go oem.
DO NOT BUY ONE YOU HAVE TO WIRE TOGETHER,they may be cheaper, but they are a pain in the ass and if you don't do it right you can wreck the sensor the first time you run the car.
which you knew
Pre cat
Awesome. Perfect info! Thank you! I'll avoid the "do your own wiring" and go oem.
Ok, this car has a 5 wire pre cat O2 sensor. I looked on rywire and all they have is the four wire. Any suggestions as to where I can get the 5 wire? Autozone/Napa/ ect wanted $400-600 for the 5 wire and that is just insane!
