es inserts on bad motor mounts???
Discussion in 'General Tech and Maintenance' started by Sleeper00, Jun 2, 2009.
  1. Sleeper00
    Sleeper00 New Member
    FLORIDA
    i need a set of motor mounts for my 92 h22a accord, i was gonna buy anchor mounts from autozone, some said do NOT get anchor, get energy suspension inserts, my questions is if i get es inserts will it fix the bad mount problem or the inserts is only for new mounts? thankx:confused:
  2. TurboMirage
    adding ES inserts to bad motor mounts will just add to your problems. replace mounts, THEN add inserts.
  3. Sleeper00
    FLORIDA
    what brand should i get, it for daily drive
  4. phyregod
    phyregod !!YTINASNI
    Central Texas
    Naa, you can put ES inserts into bad mounts. It will fix them right up, unless there is just no rubber left in the mount at all. If its just cracked a bit, slap the ES in there and call it a day. Say hello to your new rattles.. They firm up the mounts quite a bit, will give a completely different feel to the car.
  5. efhondakid
    Akron-Canton, Ohio
    Or 3M window weld.
  6. 97hatch
    97hatch ?
    Anderson IN
    plus one have dine this many times and the whole kit is only like $30 go for it it will be fine as long as there is still rubber left in the factory mounts
  7. Sleeper00
    FLORIDA
  8. CAFROG
    CAFROG Honda Minion VIP
    NOR-CAL
    Yes....I heard that the windshield weld works too.
    Its supposed to strengthen without making a bunch of vibration
    Probably a good solution if you aren't pushing 300whp+ and hate the vibration of energy suspension.
