CRX to Civic also has a different length. If you HAVE the CRX exhaust, then you can use most of it if you're tight on a budget.
The axle-over bend is also very similar between the two, regardless of the different rear suspensions. If you NEED the CRX exhaust then you can find a use for it, but you'll need to extend it and jig it up.
