Ew1 v-tech?
Discussion in 'HYBRID -> ED-EF / DA' started by close_ratio1971, Jul 17, 2008.
  1. close_ratio1971
    close_ratio1971 New Member
    ok so lets say I have an 85 CRX with an EW1 is there a V-TECH head that I could run on this? ofcourse I will also have to get an ecu and wiring harness from somewhere and convert the fuel system to high pressure but what would work and what would it come off of and what would I gain?
    Thanks
  2. INJEN78
    INJEN78 HS LEGEND
    OHIO
    you cant put vtech heads on EW's just not possible
  3. close_ratio1971
    Not possible because bolts dont line up or not possible because the pistons hit the valves or maybe oil / water passage problems come on now I need reasons
  4. INJEN78
    INJEN78 HS LEGEND
    OHIO
    ill let somone else chime in and tell you why
  5. Z6CRX
    Z6CRX übber ɐɾuıu etarip
    Pittsburgh, PA
    EW1 have a different series engine. they are not your standard D-series, even though i believe the manuals call them a d but they share few to no interchangeable parts. Either swap in a B with hasport mounts, or some other engine.
    "can i put a chevy head on my ford block?"
  6. INJEN78
    INJEN78 HS LEGEND
    OHIO
    not quite what i was getting at but that is also true
  7. INJEN78
    INJEN78 HS LEGEND
    OHIO
  8. close_ratio1971
    INJEN78
    I have noticed that you are acting like you know everything but hiding behind other peoples explanations like you don't know the answers, this shows nothing but poor character. If you really know what you are trying to make people believe you know then you would have had some answers with more substance.
    Z6CRX
    Thanks for pointing out the whole "D" series thing for me I was confused about that for some time now.
    I would like to know which if any engines share the same bell housing bolt pattern with the EW1
    fyi: in the 60's and 70's there were some instances of blocks from one motor company and heads from others being mixed though heavily modified it has happened for different performance reasons just like the manual clutch automatic transmissions.
    Blanco
    Yes I misspelled thanks for pointing it out
  9. INJEN78
    INJEN78 HS LEGEND
    OHIO
    ok,newb..you wanna call me out but you obviously havent been here long enough...
    i answer questions that i am 99% sure of the answers,if i dont know the answers i will try my best...
    you cant even spell vtec right so i doubt you have the knowleadge to do a head swap...
  10. newb
    newb phresh VIP
    Backwoods Northwest
    LMFAO! He said he would wait for others to chime in cuz it was far too easy. Thats right, you made it so easy to make a joke at your expense that he passed the oppertunity so someone else could do it. If you dont wanna get treated like a dumbass, then dont spell like one. Another tip, watch who you get an attitude with. Incase you havent noticed hes a regular here, hes not goin away cuz you dont like him.
  11. jlicrx
    jlicrx Senior Member
    Colorado Springs
    the 84-87 EW is unique and doesn't share the transmission with any other Honda - transmission to engine bolt pattern is different from anything else
