lickety_slickjj
i put a b18a1 obd0 mpfi into 91 civic dx with dpfi zc 1.6.
i wired in the the injectors and the two wires from the distributor, i keep getting crankshaft positioning sensor code. all the wires that i cut going into the ecu, i reconnected them to the same spot with the other wires. so all the wires from the dist. and injectors are going to their right places. i bought a civic ex dash and engine harness cuz i believe they are the same as the si. and i also bought an si engine harness.
should i use one of these harnesses or do you think that it is my dist. please help
