EX intake manifold on a D series engine
Liquidblaze
I have an 98 EX Intake Manifold, I bought it and the throttle body for $20. Can I bolt it up to my 98 DX. I know it should fit but I was just wandering if there is anything different about the EX intake Manifold considering it is vtec. The reason i am putting it on is it will be easier to do my turbo piping than with the DX Intake manifold.
Chris
the iacv is different. your dx has a 3 wire iacv i believe. and the ex intake mani has a two wire and your ecu wont be able to run it.
you may be able to use an ls ecu from the same obd2
