ex motor into dx
Discussion in 'Civic and del Sol - EG and EK' started by civicsickness, May 12, 2007.
  1. civicsickness
    civicsickness New Member
    wat kind of problems do i need to look for when putting a z6 motor in a dx body? im getting a ex motor in my dx cuz the b7 stock motor is done. any info would be helpful
  2. civicsickness
    ps im doin a full swap btw eng. tran. ecu.axles. everything. pretty much want to know wat kind of trouble with wiring would i run into
  3. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    what year car is it going in
  4. civicsickness
  5. AHHVTEC
    Alabama
    then drop it in bolt it up and off you go the 92 is already wired for vtec
  6. civicsickness
  7. AHHVTEC
    Alabama
    im not sure about that one i dont think so
  8. civicsickness
  9. killercannible
    killercannible Senior Member
    Its a dx, it is not wired for vtec. What does the year have to do with that, non vtec cars arn't wired for vtec. :confused:
  10. custompainter
    custompainter drive it like U stole it
    central CT
    some are wired already for vtec it depends on the year
  11. AHHVTEC
    Alabama
    92 modles are already wired for vtec in all trim even the dx
  12. jlicrx
    jlicrx Senior Member
    Colorado Springs
    absolutely correct - 92 models only
  13. killercannible
    Thats a neat fact, never heard of that before.
  14. Dasfinc
    Dasfinc New Member
    Is there a plug for the solenoid? or where would I be pulling wiring for it from?
  15. 99sidude
    Ohio
    no, your dx harness won't have the plug. You will have to use either the entire ex engine harness, or wire up the plug into your stock harness. When you say a 92 is already wired for vtec, it means that the in-car harness (runs from shock tower connectors to ecu) has the vtec wires already.
