EXEDY Clutch Kits
Discussion in 'CorSport' started by CorSport, Jan 27, 2011.
  1. CorSport
    CorSport Member
    Find EXEDY Clutch Kits for your car here
    [​IMG] [​IMG] [​IMG]
    EXEDY Clutch Kits All Cars Category
    Click here to see these products in our catalog and check out the most current pricing.
    EXEDY Globalparts, formerly Daikin Clutch, manufactures standard, medium duty, sports performance and racing clutches. In the automotive aftermarket, EXEDY products are sold over the counter in over 80 countries. EXEDY/Daikin Clutch has made clutch assemblies along with other drive train components for over 75 years. Daikin products have been present in the North America since 1968, and Daikin Clutch products have been manufactured in the United States since 1988 to serve both Original Equipment and aftermarket customers in North, Central, and South America. They produce over 70% of their manufactured products at a state of the art facility in Belleville, Michigan. EXEDY's 50,000 square foot distribution facility is dedicated to serve all of your domestic and aftermarket needs.
    If you have any questions you can reply to this thread, send us a pm or use the contact us page on our website.
    Thanks for the continued support,
    CorSport USA.
  2. CorSport
    CorSport Member
  3. CorSport
    CorSport Member
    Exedy Clutches at CorSport.
  4. CorSport
    CorSport Member
  5. CorSport
    CorSport Member
  6. CorSport
    CorSport Member
  7. CorSport
    CorSport Member
  8. CorSport
    CorSport Member
    Did you let your girlfriend drive your car again and all you can smell is burning clutch? EXEDY from CorSport has you covered!
    :D
  9. CorSport
    CorSport Member
  10. CorSport
    CorSport Member
    Need a clutch? EXEDY!
  11. CorSport
    CorSport Member
    Exedy clutches and flywheels ready to ship to your front door!
  12. CorSport
    CorSport Member
    K-Series Exedy Clutch/Flywheel Package
    [​IMG][​IMG][​IMG]
    Click here to see this product in our catalog and check out the most current pricing.
    K-Series Exedy Clutch and Flywheel Package
    Exedy Organic Stage I Clutch
    EXEDY Racing clutches with organic friction materials use only premium friction materials that are resistant to slippage and burst. Increased clamp loads give the necessary capacity to handle modified engines. The driveability will be like a stock clutch. Pedal efforts will be higher because of the higher clamp loads. All of our clutch discs have high capacity spring center dampers to reduce the drive train shock and impact.
    Exedy Cerametallic Stage II Clutch
    EXEDY cerametallic clutches are designed to handle the abuse of high power modified engines. The cerametallic friction material can handle much more slippage than stock type disc assemblies without slipping and fading.
    All EXEDY cerametallic clutch discs have spring center dampers to reduce the impact and shock loads put into the drivetrain. This protects the transmission and the rest of the drive line system.
    With any cerametalic clutch system, there will be some compromise of start up driveability as compared to a stock clutch (chatter on light throttle, low rpm start up). This characteristic is general felt to be acceptable in modified performance cars. Drivers of cerametallic clutches on the street should be warned not to "ride the clutch" to try to reduce the chatter as this will greatly increase the wear.
    Exedy 9LB Lightweight Flywheel
    Exedy Racing Flywheels are made from solid one-piece billet chrome moly steel or chrome moly steel forgings. They are specifically designed to reduce weight and inertia for better engine response. Most incorporate special design features to enhance the air flow to improve the cooling of the clutch. The ring gear teeth are milled onto the flywheel unlike an aluminum flywheel where the ring gear is pressed onto the flywheel which has the possibilities of separating from the flywheel. This could cause the flywheel to explode due to two different expansion coefficients (aluminum flywheel pressed on steel ring gear). EXEDY steel billet and forged steel flywheels have passed engineering tests to 15,000 rpm. They are guaranteed to be explosion proof at the said rpm.
    For but not limited to the following applications : K20A2,K20A3,K20Z1,K24A2,K24A4,K20Z3
    CorSport USA.
  13. CorSport
    CorSport Member
