Exedy Stage 1 full face organic clutch kit
Discussion in 'General Tech and Maintenance' started by ACE4DOOR, Jun 27, 2005.
  1. ACE4DOOR
    ACE4DOOR Member
    Okay, I'm used to a stock clutch but it's going. Will the Stage 1 Exedy I mentioned in the title be much harder? meaning will my left leg be sore from having to press extra hard on the pedal. I drove my boys B16 coupe with an ACT kit and I'm hoping it's not anywhere close to that hard. I don't want one leg bigger than the other.
    By the way it's for an everyday driven B20vtec EG w a B16 tranny.
  2. formby
    formby learning in progress
    get what ever you want as long os it has a sprung hub....i have a 3puk excedy and its not that hard...but youll be fine with the stg 1
  3. UDT
    UDT Senior Member
    california
    It will be much less then anything ACT has, you should be ok.
  4. noobvang
    noobvang Senior Member
    Twincities, MN
    Just a little noticable from a stock feel, nothing near an ACT.
  5. asmallsol
    asmallsol Super Moderator
    Houghton/Livonia Michigan
    Basicly feels like stock after 10 mins. of driving. Its a little firmer, but not much. Very streetable.
  6. phyregod
    phyregod !!YTINASNI
    Central Texas
    :concur: I ran that cluch with my si motor, worked fine. I currently run an exedy stage one in my 97 integra..
    Not much different from stock. After a little bit you wont even notice.
  7. PLA5151
    PLA5151 New Member
    Puget Sound area
    just got my exedy clutch 2 wks ago for my H22A, honestly feels stock putting it into gear but if you go at it on the freeway you notice the grab considerably going 2nd to 3rd 3rd to 4th etc...I'm very happy with it
  8. VTECPOWER
    VTECPOWER Senior Member
    Winchester, VA
    :withstupid:
    I have one in my b16 crx and I love it, its grabs quite nicely when I get on the car going onto the highway from 1st to 2nd or 2nd to 3rd.
  9. phyregod
    phyregod !!YTINASNI
    Central Texas
    :werd:
    You can definently feel the extra grab that it has.. Much better than stock.
