Exhaust Question
Discussion in 'General Tech and Maintenance' started by NickBeam, Jul 7, 2008.
  1. NickBeam
    NickBeam New Member
    Ky
    I'm thinking about getting a test pipe or a highflow cat. My car has been converted to OBD1 which I believe doesn't monitor your catalytic converter effeciency. So does that mean I won't get any codes or a rich fuel mixture without doing anything other than just installing the pipe?
  2. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    it will be fine with a straight pipe
  3. 91accordwithwork
    91accordwithwork kid that everyone loves!
    Wauwatosa WI
    im doing the same from a scale of 1 to 10 how much luder will the straight pipe be from my old rusted cat
    thanks
  4. YBLEGAL
    YBLEGAL Regular Member w/ Cheese
    NW Indiana
    haha, 8-9 depending on where you are in the rpm band.
    It's much louder, and more shrill (with my exhaust)
  5. 91accordwithwork
    Wauwatosa WI
    ok cause righ tnow its not very loud at all so i thought that if i put in the new resonator it wil be good, but u think it will be tooo loud?
  6. BrutalB83
    Rochester Hills, MI
    If you do remove your cat then be sure to put the resonator in, otherwise it will be ridiculously loud...
  7. Slow&Delirious
    Slow&Delirious isn't fast or furious
    Boonville NC
    i hate loud, espceially when people mess with the cat or cut holes in stock mufflers
    mustang cobra with flowmaster or magnaflow mufflers is a sound of beauty.
  8. YBLEGAL
    NW Indiana
    If I'm reading you straight, your confused, because it seems you think a catalytic converter is also a resonator. A resonator is a restrictive, sound redirecting piece of material, usually made of metal, that is generally offered as a removable in most mufflers. Again, a resonator does it's job in the muffler. A catalytic converter is restrictive due to the chemicaly fortifed walls on the inside and the nature of how it works. Since it's restrictive, it also dampens sound waves from the engine.
    And if I'm wrong, and your not confused, o well lol
