Exhaust Question
Discussion in 'General Tech and Maintenance' started by lswhitecivic, May 15, 2005.
  1. lswhitecivic
    lswhitecivic Senior Member VIP
    DFW, TX
    Does anyone know if the length of a b pipe on a civic hb and a gsr are the same? I have a cat that I made fit a gsr b pipe that then has my civic axleback on. I am looking at getting a whole catback system and I'd like to not have to do anything custom. Otherwise I'm gonna have to get a b pipe for a gsr with a civic axleback to make it fit.
    Hopefully that makes sense.
    Thanks
  2. EGProject
    EGProject YEEEEAAHHHHH
    Whitinsville, Massachusetts
    From what I've seen personally, I can make the assumption that Integra B-Pipe is similar to the Civic Coupe pipe. I'm not sure if the B-pipe is different, or if the axle-back is changed.
  3. sk8er602
    sk8er602 Senior Member
    Athens, Ga
    i THINK that the integra exhaust is shorter, bu i very well could be wrong so hopefully someone will now for sure.
  4. TWISTEDIMAGE
    TWISTEDIMAGE Senior Member
    CASPER WYOMING
    i think they are diff too
  5. PhyRe
    PhyRe Senior Member
    ct
    i have a 93 hatch with 97 gsr header cat and mid ppipe(this is b?) and all bolts up and lines up right but i have a broken bolt in the axle flange so i was never able to put the muffler back on. but from what see it will def fit. but dont try and use a gsr or coupe muffler because they are too big. only hatch
