Exhaust Wrap
Discussion in 'General Tech and Maintenance' started by TurboRex90, Jan 12, 2011.
  1. TurboRex90
    TurboRex90 Golden EG
    Maryland
    So i just picked up a *new* exhuast for my Eg. Was looking into either High-temp painting the piping black to prevent wear/rust.. Or going the Exhaust Wrap path.
    So two questions:
    1.Should I High-Temp paint the Downpipe back, minus the muffler?
    2. Use exhaust wrap from the Downpipe back?
    And if i go with Exhaust wrap, does anyone know how many feet of wrap i should get? Ive never heat wrapped such a large object before. Also, should i use Ceramic, Titanium, or Fiberglass wrap?
    thanks!
  2. E_SolSi
    just paint it
    thermal wrap is exactly that... it does not protect against rusting... if anything it probably promotes it
    the wrap is going to get wet and covered with grit when you drive on less than perfect days
  3. K2e2vin
    K2e2vin Senior Member
    Raleigh, NC
    There are a couple of guys who've disproved that thermal wrap promotes rust(they had rust in the areas where there was no thermal wrap). Though, in the down-pipe/header area it's not really going to get wet unless you're hitting puddles or plowing through snow. Also, this is the header only, which gets hotter than most of the rest of the exhaust system.
    Best method would be SS or aluminum piping.
    If anything, wrap just the downpipe and paint the rest of the exhaust.
    1 person likes this.
  4. lostsoulzprophet
    lostsoulzprophet delslow
    georgia
    i would of got ss piping but since you didnt paint it.
  5. TurboRex90
    Maryland
    Its a Fujitsubo exhaust, since they dont make these new anymore, its hard to be picky with SS/Aluminum. So ill Wrap my Manifold/Downpipe, and Paint the exhaust.
    Is 50' enough for a ramhorn manifold / 3"downpipe? Or is 25' enough..
    Thanks guys!
  6. lostsoulzprophet
    georgia
    ahh i see. 25 should be enough.
  7. hondafreak513
    hondafreak513 New Member
    O hi O
    Paint it first then wrap it..
  8. TurboRex90
    Maryland
    Paint and wrap the whole manifold back? or Just Paint and wrap the exhaust, and wrap the manifold and DP.
  9. hondafreak513
    O hi O
    Paint it all and just wrap the manifold, you can wrap the DP but I have never seen anyone do that. They usually just wrap the manifold as it gets the hottest...
  10. TurboRex90
    Maryland
    Shit, ive even seen people wrap the intercooler piping, both hot and cold side.
    So i was just curious as to if i should wrap the downpipe or not.
  11. hondafreak513
    O hi O
    Are you talking about the turbo DP if so then yeah wrap that shit...
  12. TurboRex90
    Maryland
    yeah, what other kind of downpipe would i have? o.0
  13. hondafreak513
    O hi O
    I thought you said, you was going to run the non turbo motor for a bit, then put the turbo motor in later...
  14. TurboRex90
    Maryland
    Well ya i am, But im talking about down the road.. I plan to wrap the DP and manifold.
    I guess we got a bit off topic. But i got a clear answer now, Thanks.
    +1
  15. hondafreak513
    O hi O
    Ok I see... Have you put a motor in the car yet...
  16. TurboRex90
    Maryland
    I havent had the stop, i managed to yank it from the crx, but i had to order a few replacement parts while the motor was out to kinda "spruce" it up a bit. Once the process starts, ill start snapping pics and start a thread.
  17. reckedracing
    reckedracing TTIWWOP VIP
    NY
    i would look into the thermal qualities of pur-15
    it will def keep your shit from rusting and its said to turn to like a ceramic/glass type of material when it dries
    might be like a ceramic coated DP and exhaust
    and will prevent the rust
  18. TurboRex90
    Maryland
    Well I picked up some Flat silver 2000 degree Engine paint. They were out of black, and the silver will make it look good again unless you get real close underneathh.. mehh.
    Im gonna spray bomb the exhaust and wrap the manifold/downpipe.
    :D
