exhuast header choice help
Discussion in 'Engine Building' started by gatto-is-alive, Jul 4, 2010.
  1. gatto-is-alive
    gatto-is-alive New Member
    EARTH
    need to choose between full 4-1 and the new tri-y style header for a b16 with 12.0:1 cr
    which way i have to go ????????????????????????????????????????????:confused:
  2. 78civic
    78civic Junior Member
    NW MS, Y'all
    That all depends on what you/whomever will be using this particular engine for..
    4-1 is more for upper RPM's
    4-2-1 is for more torque in the lower RPM's (some say gets better scavenging and a smoother running)
    E
  3. intenseneal
    intenseneal New Member
    I would go with a Hytec Tri-y replica header, they can be had new for under $200. They are a great header for high reving high compression Vtec motors. Check out Ebay for one. I use a no name 4-2-1 on my B18B1 and it works well for my set up. I am building a Vtec head now and am thinking on going with this header.
