Are these prices bout right? Or could I find them for cheaper than I have listed.. or would they be more expensive? I'm tryin to get an idea of how much I'll be spending on everything just to get my finances planned out. Plz help me get an idea of what something costs.. these are prices I found on internet websites and ebay etc.. but ebay isnt the best thing to go off of for pricing..
B18b bottom end - $400
B18C1 head - $1000
18" -4AN steel braided hose - $75.00
2 x -4AN fittings -----
1/8"NPT to 1/8" BSP Tee fitting -----
1/8"NPT to -4AN adapter fitting -----
-4AN to 3/8NPT fitting -----
1/8"NPT plug -----
SRP Pistons 9:1 - $450
Eagle Rods & arp rod bolts - 374.99
arp head bolts - $109
rc injectors 550 cc - $140
oil catch can - $112.70
z10 block girdle -
Golden Eagle Godzilla Sleeves - $1000
Turbo Grind Cams - $850
Cam Gears - $100
Turbo Kit - Full Race Motorsports $4500
Port/Polish - $500 -- MIGHT NOT NEED
Machine Work on Head/Block - $150
Hondata s200 w/ boost option - $500
p28 ecu - $325
B18C1 Tranny w/ Quaife LSD - $900
VTEC Shift Linkage - $400
Golden Eagle Fuel Rail - $100
B Series Distributor - $500
ACT Clutch - $600
Axles (aftermarket) & Mount Brackets (HaSport) - $700
Traction Bars (jimfab.com) - $500
VTEC Oil | Water Pumps $150
OEM Timing Belt $80
Replace Gaskets $200
Anyone who helps me.. THANK YOU SO MUCH!
B18C1 head - $1000
1/8"NPT plug -----
z10 block girdle -
Cam Gears - $100
p28 ecu - $325
ACT Clutch - $600
OEM Timing Belt $80
