You kinda have to "guess" where the clips are behind the molding(trim), and use a flat screw driver with an angled tip. Kinda like a tool you would use to remove a hose from its pipe. You have to get just beneath the clip and turn the driver towards your body.
Or you can just try to pop it off without breaking it and just replace the clips with oem honda replacements.
