extra sensor
racintweek
im inthe proces of doing the mpfi wiring and i noticed there is sensor on the coolant flange on the side of the engine and there wasnt one on my STD engine
do i use that sensor? if so what plugs into it?
help!?!?!?
help!?!?!?
[post=426931]Quoted post[/post]​
is the B18 engine OBD1? is the sensor on the thermostat housing? if so, it is the cooling fan switch which is next to the oil filter on D15 engine - harness connector has 2 wires with big black rubber boot - you need to extend wires to reach the sensor
yes the LS is OBD1
so i leave the sensor on the block unplugged and connect those wires to the sensor t-stat housing?
