F/S 02 Honda S2000
sivtec 99
I am selling this for my buddy who just bought a townhouse and no longer can afford 2 car payments.He bought this for his girlfriend who drove it all the time.Never been beat on,never been raced.She drove it to work and to some meets.Car has 40000 miles.The car is red with black leather interior.It is bone stock no mods have been put on.
New price of $21500
Engine
Type
16-Valve DOHC VTEC Inline-4
Bore & Stroke (mm/in.)
87.0 x 84.0/3.42 x 3.30
Displacement (cc/cu. in.) 1997/121.9
Horsepower (SAE net @rpm) 240@8300
Torque (lb.-ft. @ rpm)
153@7500
Block Material Aluminum Alloy w/Fiber-Reinforced (FRM) Cylinder Walls
Cylinder-Head Material Aluminum Alloy
Valve Train 16-Valve DOHC VTEC
Lightweight, MIM (Metal-Injection Molded), Sintered-Steel Rocker Arms, Low-Fricition Roller-Bearing Cam Followers, Compact, 2-Stage Cam-Drive with Silent Chain, Scissors Gears and Fully Automatic Tensioner
Fuel Induction System Multi-Point Programmed Fuel Injection (PGM-FI)
Ignition System Electronic
Emission Control Low Back Pressure, Metal-Honeycomb Catalytic Converter
Electric-Motor-Drive, Multi-Port Secondary Air-Asist Injection System
Recommended Fuel Premium Unleaded
Compression Ratio 11.0:1
Powertrain
Drive System Type Front Engine/Rear-Wheel Drive
Manual Transmission 6-Speed w/Torque-Sensing Limited-Slip Differential
Transmissions Gear Ratios:
1st gear 3.133
2nd gear 2.045
3rd gear 1.481
4th gear 1.161
5th gear 0.971
6th gear 0.811
Reverse 2.800
Primary Gear Reduction 1.160
Final Drive Ratio 4.1
Chassis
High X-Bone Monocoque Frame
Front Suspension Independent In-Wheel Double Wishbone & Coil Springs w/ Stabilizer Bar (28.2 mm)
Rear Suspension Independent In-Wheel Double Wishbone & Coil Springs w/ Stabilizer Bar (27.2 mm)
Shock Absorbers Gas- Pressurized Mono-Tube
Steering Type Electric Power Rack-and-Pinion
Steering Wheel Turns (lock-to-lock) 2.4
Steering Ratio 13.8
Turning Diameter (ft., at wheel center) 35.4
Wheels: Front 16" x 6.5" Aluminum Alloy
Rear 16" x 7.5" Aluminum Alloy
Tires: Front Bridgestone Potenza S-02 P205/55 R16 89W
RearBridgestone Potenza S-02 P225/50 R16 89W
Ventilated Front Disc Brakes (diameter) 11.8 in.
Rear Disc Brakes (diameter) 11.1 in.
Parking Brake Rear Mechanical
