goldgreen90ef
goldgeen90ef
i have a 90 gray dx for sale that is currently NOT running.(turns over may need fuel pump or main relay)car is in akron ohio and has a clear ohio title, with a little work could be back on the road easy
the bad:
car is currently not running
needs a hood(hood latch area is damaged but repairable)
needs a ecu (pm6 obd0 crx/civic si)
needs vtec controller
needs 02 sensor
passenger fender dented
the good:
obd1 jdm sohc vtec d15b(130 hp, about 50k miles) installed feb 06
crx si transmission (4.20 gears,about 120k miles)installed feb 06
exedy clutch,throwout,pilot bearings, installed feb 06
venom injectors installed feb 06
95 si intake manifold and throttle body(car wired for multi point fuel injection)
re-maned distributor,installed feb 06
chikara header
94 accord cat
pace setter cat back exhaust system
newer radiator and front brakes
interior in good shape(gray, needs a cleaning)
also included in sale, two doors w/glass,hatch w/glass,rear side glass, and a timing belt and water pump
car is located in cuyahoga falls ohio 44221 near akron and will need to be towed
thanks message me with any questions robbie
the bad:
needs 02 sensor
the good:
chikara header
94 accord cat
