F/S: '92 Civic Si w/ GSR swap
iberian_wolf
Up for sale is my '92 Civic Si with a USDM GSR swap, located in Gaithersburg, MD.
I've had the car almost 3 years and the motor for almost 2. The chassis has 154K on it
and the motor has around 120K. I don't know the motor's mileage exactly but it doesn't
use any oil or leak anything, and hasn't given me any problems. The transmission was
pulled a year ago to have 3rd/4th gears replaced and the LSD installed. The A/C, power
steering and cruise control are all in working order and the interior is very clean.
Under the hood:
- 94 GSR Engine/Transmission
- DC Sports 4-1 Header
- Skunk2 Intake Manifold
- Short ram intake
- Apexi WS cat-back exhaust and high flow cat (not loud)
- MSD ignition wires and cap w/external coil
- Clutchmasters stage 1 clutch and flywheel
- B&M short throw shifter
- New clutch master and slave cylinders
- ITR helical LSD
- Urethane motor mount inserts (torque mounts only)
- Del Sol dual core radiator
- Chipped P28 ECU w/datalogging port and cable (stock GSR fuel/timing currently)
Supsension/Brakes/Wheels:
- Tanabe Sustec Pro SS coilovers
- GSR front swaybar
- Comptech rear swaybar/tie bar combo
- Front brakes upgraded to 10.2" w/ 40/40 prop valve
- Integra LS 7/8" master cylinder and booster
- Brembo blanks all around with Axxis metallic pads
- Goodridge SS brake lines
- 15" Rota Slipstreams w/ 205x50 Kumho Ecsta 712s
Other:
- Oil pressure gauge/voltmeter
- Alarm w/shock sensor
- Clarion CD/MP3 stereo (not installed yet) and Infinity speakers
- Set of steelies w/ all season tires
Bad stuff:
- Repainted a couple years ago, but it's gotten a few small dents and stuff since then.
- Rust is starting to bubble the paint in a small spot on each rear wheel well
- Noticeable scuff on front driver's corner (paint rubbed off, no bumper damage)
- Needs a new cat.. does not pass MD emissions, test results indicate a bad one.
The cat is a Carsound and I got it used, so it's probably shot.
The price... $6000. VIN available upon request.
PM or email me if you're interested or have any questions... iberianwolf@comcast.net
Thanks for looking!
More pictures:
http://i66.photobucket.com/albums/h248/ibe...driver_seat.jpg
http://i66.photobucket.com/albums/h248/ibe.../honda/dash.jpg
http://i66.photobucket.com/albums/h248/ibe...nda/console.jpg
http://i66.photobucket.com/albums/h248/ibe...da/backseat.jpg
http://i66.photobucket.com/albums/h248/ibe.../honda/rear.jpg
http://i66.photobucket.com/albums/h248/ibe...frontcorner.jpg
http://i66.photobucket.com/albums/h248/ibe...nda/swaybar.jpg
http://i66.photobucket.com/albums/h248/ibe...a/rearwheel.jpg
http://i66.photobucket.com/albums/h248/ibe...onda/speedo.jpg
http://i66.photobucket.com/albums/h248/ibe...da/rearsusp.jpg
http://i66.photobucket.com/albums/h248/ibe...a/pass_side.jpg
http://i66.photobucket.com/albums/h248/ibe...nda/motorid.jpg
http://i66.photobucket.com/albums/h248/ibe.../intake_man.jpg
http://i66.photobucket.com/albums/h248/ibe...onda/intake.jpg
http://i66.photobucket.com/albums/h248/ibe...onda/header.jpg
http://i66.photobucket.com/albums/h248/ibe...honda/hatch.jpg
http://i66.photobucket.com/albums/h248/ibe...onda/gauges.jpg
http://i66.photobucket.com/albums/h248/ibe.../frontwheel.jpg
http://i66.photobucket.com/albums/h248/ibe.../driverdoor.jpg
My buddy just got 5500 for his lsvtec 92 dx hatch that didnt even have interior pieces due to a roll cage so im sure he can et around what he wants for it.
Quoted post[/post]]
Quoted post[/post]]
No offense, but a usdm motor, 120k miles.
I can see 4k
You'll be lucky to see 5k just for the reason that it is a USDM motor that has 120k on it already, even with the mods on it.
