Boosted4dr
Member
Here is a list of all my Parts for sale. There is no prices yet i am going to see if there is any interest before i price out. Pictures will come upon interest also. Almost Everything here is Used But Works. I need to rebuild my Race D16z6 due to tuning issues, so this is my shot for some xtra cash Thanks Boosted4dr
92 - 95 Civic Power Stearing Rack
92 - 95 Civic Left & Right Upper Control Arms
D16z6 Driver Side Axel with Inner Full C/V Boot
92 - 95 Civic Catalytic Converter
D16z6 Flywheel, Clutch, Pressure Plate. ( Like New )
t3/t4 turbo needs Center section and shaft
D16z6 Intake Manifold w/ Idle Air Control Valve and throttle cable
92 - 95 Civic Inner Tie Rod Boots
92 - 95 Civic Inner Tie Rods ( Power Stearing )
D16z6 Spark Plug Wires ( 2 Sets )
92 - 95 Shifter ( 2 )
D16z6 Vtec Solenoid
D16z6 Fuel Injectors 240cc
OBD0 Distributor
OBD1 Distributor
Purge Control Valve
D16z6 Valve Cover
D16z6 Bare Intake Manifold
D16z6 Bare Head
92 - 95 Civic 4dr Muffler ( stock )
92 - 95 Civic 4dr Front & Rear Brake Lines ( stock )
92 - 95 Civic 4dr Front Rotors ( stock Need Resurface )
D16z6 Block with Pistons, Rods, Crank, Girdle ( Assembled needs rebuild all components good )
D16z6 Crank shaft Pully supporst Alt, P/S, A/C
D16z6 Oil Pan
D16z6 Exaust Header and downpipe ( 2 )
D16z6 Shift Linkages
D16z6 Si Cable 5 Spd Transmission
D16z6 Ex Hydro 5 Spd Transmission ( Grinds )
D16z6 Pressure plate and Clutch disc ( smaller diameter came from the Cable Tranny. Good )
92 - 95 Civic Left and Right Headlights
92 - 95 Civic Left and Right Taillights
T4 Turbine Housing w/ Seal Plate ( Good )
T3 Compressor Housing ( Good )
D16z6 Oil Pump ( 2 )
D16z6 Pistons and Rods ( Need Rings ) Used
D16z6 Water Pump ( Used )
D16z6 Stock Cam Gears ( 2 )
D16z6 Water Pump Housing
D16z6 Throttle Body w/ TPS sensor
92 - 95 Civic Rear Tail lights ( Reverse Section )
D16z6 Fuel Rail And Pressure Regulator ( Stock) (2)
D16z6 Cam Shafts ( 2 )
Yokahama Avid t4 Tires ( 205,15.50 ) Good condition ( 2 )
D16z6 Unorthodox Racing Power Stearing Light weight Pully
Complete 93 EG4(EDM) D15B2 5sp-------PM3-8 (9/4) stamp ( Cylinder Head Need Seels )
Any Motor Mount you need for a dseries motor
D16z6 Vtec Solenoid
OBD0 Distributor
OBD1 Distributor
Purge Control Valve
D16z6 Valve Cover
D16z6 Bare Head
D16z6 Oil Pan
