MD F/S: Built B18 Block
Discussion in 'Parts: For Sale/Trade/Wanted' started by tricura, Feb 2, 2011.
  1. tricura
    tricura Member
    Finksburg
    I am selling a fully built sleeved B18A short block with Wiseco pistons, Eagle H-beam rods, Eagle light weight knife edged crank, ACL bearings, and new seals all assembled and read to go.
    This block will handle in the upwards of 800hp, it can be used for turbo, supercharger, nitrous or just all motor. It does have the oil pump and some extra little parts with it. If you tried to build this on your own it would be over $4500 to do so. Asking $2500/obo and looking for serious inquiries only.
  2. lesroy
    lesroy New Member
    what is the cylinder bore
  3. LOWLIFE
    LOWLIFE Local Diesel Fanatic
    Fort Worthless
    and compression ratio of the pistons, what sleeves, been decked if so how much, ect.
    When you are selling a "built" block it is best to post all that you can about it, such as machine shop that performed the work, all the brands of parts, and all that jazz. Just trying to help.
  4. tricura
    tricura Member
    Finksburg
    84mm
    Thanks, I understand what you mean. There are to many flakes out there, serious people will already understand what is is intended for. There questions will be answered.
