F/S EF look engine package LOTS OF STUFF
jschnatter
Ok, I was planning on big things for my CRX but cannot finish what I started. Ok, I'll be honest, I didn't even start. All I did was buy everything. Here is what I have:
B18b imported from Japan by Engine Depot <40000 miles
ACT Stage 2 Clutch/9lb flywheel
S1 Cable Trans. - 75000 miles
Hasport Motor Mounts and Shift linkage
Full (headlights to taillights) OBD1 Wiring harnes-complete with guage cluster, ignition w/acura key, fuse boxes(interior and under-hood) headlights/taillights, all switches needed and ECU.
Full Turbonetics Turbo Kit - T3/T4 Turbo, BOV, Turbo Timer, Digital boost control, Intercooler, external waste-gate, MF2 (fuel mapping computer), 2 extra 550cc injectors which connect to the pipe b4 the throttle body, wide band air/fuel meter, all pipes needed, downpipe.
EVERYTHING LISTED FOR 2500$!! Everything in perfect working condition.
E-mail JS565450@wcupa.edu or call 9085076106 - Leave a message-Located in NJ
engine, act clutch/flywheel and trans (all attached) 850 cash
paid 800 for engine
500 for clutch package
300 for trans
used 2000 miles
