F20B=95 accord lx
Discussion in 'Accord' started by sivtechatchy, Jun 11, 2010.
  1. sivtechatchy
    sivtechatchy New Member
    i need help i need to no every part i need for the swap plz asap also i will not be using p/s or a/c 95 accord lx cd7 also if u no a DIY THREAD PLZ HELP
  2. f22b1 coupe
    f22b1 coupe Junior Member
    Indiana
    Have you ever swapped a Honda engine in general? I mean, literally, auto zone sells a honda swap book haha. It's a pretty direct swap you're talking about since you don't car about retaining PS.
  3. BrutalB83
    Rochester Hills, MI
    That's a bolt-in swap. You can reuse the stock mounts. The only thing you'll need to do is wire up VTEC (assuming that the engine is the same OBD as the chassis). If the engine is OBD2, then you'll need a conversion harness...
