F20b/h22a
Discussion in 'HYBRID -> BA-BB /CA-CD' started by honda_mach3, May 9, 2003.
  1. honda_mach3
    honda_mach3 Senior Member
    My younger brother will be doing a swap in his 94-95 accord. Will the F20B be a direct drop in? What about the H22, will it be a direct drop in too? the accord is an auto so what else will i need to convert to manual? Does the F20B has secondary runners like the H22 and B18C? anything will help.
  2. dohcvtec_accord
    dohcvtec_accord WRX Sellout
    The left lane
    As far as I know, the F20B never came OBD1. So it wouldn't be a direct drop-in, in that you'd either have to get a conversion wiring harness or do the wiring manually.
    The F20B is more expensive, has less torque and the same hp numbers as the JDM H22A. Unless he's buying it "to be cool/unique/whatever", the H22 is probably a better choice. It'll be less expensive, and you can get it OBD1, which makes it more or less drop right in.
    Check the forums for info on how to do an auto/manual swap.
