Well nice quote off of Wikipedia anyone could have searched and known the f20b was created to run in the 2 liter class but anyways, I know this reply come months later but if you have anymore f20b questions just pm me...the f22,f23,h22,h23 all use the same clutch,pressure plate, and flywheel...all the h22 parts will fit your f20b except the piston and rods...just so you know if you have an auto version of the f20b you got screwed because it's not rated at 200hp the manual version has h22 type s cams and throttle body to produce that extra little bit of horse power to put in at that 200hp mark. But to answer your question, which I'm sure you already figured out, YES the h22 clutch system WILL work
