F20B Swap into 99 Accord Sedan
Discussion in 'Accord' started by lightspeedaccord, Sep 2, 2007.
  1. f20baccord
    f20baccord New Member
    I am doing the same swap right now, I have a 2000 accord coupe f23a, and I am swapping a f20b, anyone have any idea on the wiring for the distributor?
  2. iii76
    iii76 New Member
    same as your stock motor, just remove sensors, bolt motor to your stock tranny, connect sensors, change over ecu, enjoi
  3. oToKoTo-TsOi
    oToKoTo-TsOi New Member
    I am doing the same thing on my friend's 98 accord with F22 SOHC engine swapped to F20B DOHC Vtec with LSD Tranny. The only problems I am encountering is that the two main plugs from the right front panel under the fuse box. I changed them into the same color coded wires that corresponded to JDM F20B plugs and the ECU has 4 extra wires that needs to be solder into something? A plug - White/Black stripe and 1 silver paint, Red/Yellow stripe with 2 silver paint, Green/Red stripe (ELD)with 2 silver paint and Gray with 2 silver paint.
  4. crusemegois
    crusemegois New Member
    What's necessary for f20b into 96 cd7 stock with f22b1 obd2
  5. dilbeckskate
    dilbeckskate infamous
    Kennesaw Ga
    You realize this post is from 2011 right
