F20C possible in a eg hatch???
Discussion in 'HYBRID -> EG-EK / DC' started by malexander, Jan 31, 2008.
  1. malexander
    malexander New Member
    I'm wondering if a f20c swap would be worth the money and how much fabrication would be needed? Would it be worth the efforts? 240 hp is alot for a stock motor.
  2. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    any thing can fit with a welder,,i mean there are civics with ls1 motors in them
  3. BrutalB83
    Rochester Hills, MI
    Shit loads of fabrication would be needed. Not worth it in my opinion. You can drop an H22 and make 200 horsepower/160 ft/lbs torque for probably a third of the money you'd spend on an F20C conversion.
  4. AHHVTEC
    Alabama
    also there are fwd k series motors that are bone stock making 240 hp.in stock trim
  5. reikoshea
    Dallas, TX
    there is a guy in dallas that has done it, but as the above states...its not worth the money...stick some cams in a k20a and call it a day.
  6. BrutalB83
    Rochester Hills, MI
    True dat. Also, the F20C/F22C doesn't actually respond that well to bolt-ons. It's tuned so well from the factory that there's not really a lot you can do to it aside from turbo or supercharging.
    The K-series on the other hand responds very well to bolt-ons and tuning. I'd look towards the K-series or an H22 instead. You'll have a lot less headaches.
  7. malexander
    my problem with k swap is that im in cali and would want to get it BAR'D and it would need the motor, ecu, and ignition to have matching numbers. Plus something about the fuel feedback line or something. But i have considered a k20a swap.
  8. AHHVTEC
    Alabama
    so what make the f series easier on that note
  9. BrutalB83
    Rochester Hills, MI
    You're worried about passing Cali inspection and you think an S2000 motor is somehow more likely to pass than a K-series???
  10. malexander
    i was compelled to ask because i had never heard, so i knew about the k20 but didnt know about the f20. that is all.
  11. AHHVTEC
    Alabama
    any motor that didnt come stock in it in the usa will have a problem
  12. malexander
    well b series swaps are relatively easy, relative to a k20.
  13. AHHVTEC
    Alabama
    when it comes to passing bar i would think a jdm b and a jdm k series should be about the same but then again i have no clue i live in alabama lol
  14. malexander
    With a k series you would have to pick up a front clip for like 5 or 6 grand. Because the ecu has built in security and emissions control which in order for the stock ecu to work properly you would need the original ignition and the original key. its just a mess to pass a k series through the ref.
  15. AHHVTEC
    Alabama
    you can get it re keyed for 100 bucks or buy a kpro and pass it all together
  16. malexander
  17. AHHVTEC
    Alabama
    its a ecu upgrade that you can fully tune, it lets you shut off obd2 and immobilizer and a bunch of other stuff
  18. malexander
    for real? but i think the ref looks at the serial numbers on the ignition and ecu and they are supposed to match up or you will automatically fail it... but i could be wrong, i hope someone can tell me for sure so if i were to do it i dont spend the extra money for a front clip.
  19. AHHVTEC
    Alabama
    so are you saying the numbers on the ecu is to match to your car or the motor
  20. malexander
    the emobilizer on the ignition needs to match the ecu...
