(F20C-S2000)+(F20B-Tranny)=FWD 250HP
Discussion in 'HYBRID -> EG-EK / DC' started by Riceras, Jan 18, 2005.
  1. Riceras
    Riceras Senior Member
    Dallas, Texas
    I think this swap would be great?
    Question to drop this into an EK9 would I just get the hasport kit to drop in an H22?
    Would this actually work though I dont know the F-Series Very Well!!! B)
  2. 92civicb18b1
    92civicb18b1 The Trisexual
    i think the f20c spins in the opposite direction, also the mount locations are in different places.
    I doubt the f20b trans bolts up to it.
    You'd be much better off with an h22 or any be series turboed or whatever to make the 250 goal.
  3. civiclxb16
    civiclxb16 Senior Member
    Poconos pa
    i was wondering if it worked as well i wish it did tho but he is right it spins in the opps direction
  4. nismogod
    nismogod Senior Member
    Deltona, FL
    i'm under the impression that the f20c is nothing like the other f-series engines. just like the b20 in the old preludes isn't like the other b-series engines.
  5. phunky.buddha
    Dallas / Fort Worth, TX
    You can mash the K series transmission and the F20C together and try to drop it into an EK...
  6. dohch22a4
    dohch22a4 Senior Member
    Spokane, WA
    The F20C is pretty much an even more asskicking K20A. The designs are very similar and I've even heard that the cams are interchangable. The look like the same friggin motor other than the intake manifold and the fact that it's a RWD engine.
  7. Riceras
    Dallas, Texas
    If that was possible think of the Possibilities??????
    I would love to have ALL-Motor 250HP Stock FWD
  8. ej11
    ej11 Member
    SO CAL!!!
    HAHAHA!!!!!
    I WAS THINKING THE SAME CHIT THE OTHER DAY...
    (F20C,F20B TRANNY... TO BAD IT WON'T WORK...WILL IT? :blink:
  9. pissedoffsol
    you can. you just need to build it.
    k24 tsx block
    k20a jdm itr head
    add
    i/h/e
    250 crankhp for sure.
  10. formby
    formby learning in progress
    i was looking into that swap but at the moment its way to expensive and time consuming
