f22 engine swap problem need help
Discussion in 'Accord' started by TYLER 23, Nov 21, 2013.
  1. TYLER 23
    TYLER 23 New Member
    I have a 96 ex vtec auto car. I just dropped my engine from my 95 obd1 accord. its all together turns but want start got an issue the car needs a crank sensor to make it run ,but the obd1 engine doesn't have one. I need more info in jumper harnesses. What parts are involved. I cant just get 95 entire car harnesses and computer and ect.doesn't work been there done that. Any info will be appreciated. Thank you. :)
  2. calmfornow
    calmfornow System Failure Racing
    Zionsville, pa
    Buy an obd2a to obd1 jumper harness and use the obd1 ecu
  3. calmfornow
    Zionsville, pa
    It will be plug and play
