F22-H22 swap
Discussion in 'Prelude' started by dogzilla, Nov 5, 2008.
  1. dogzilla
    dogzilla New Member
    Hey guys, new to the site just wanted to say whats up
    I was looking for information and couldnt find it
    I had a few questions regarding a F22 to an H22a swap.
    1. How easy is the swap, this will be my first and i dont want to get in over my head
    2. What parts if any can be transfered over from the f series to the h22a
    3. Is the f22 an OBD 1 or 2, and the h22a 1 or 2. How hard would a 1 to 2 conversion be.
    4. Ive seen plenty of H23-H22 guides, is the F22 a similar swap.
    5. If my prelude was pre-wired for vtec (got a 1995 S) where would it be
  2. pfcchurch
    pfcchurch Have u had ur VTEC
    Lincoln, AR
    I am doing the same exact swap in my '93 accord. Both engines are obd 1. All that you need to do is of course buy the engine, if it was prewired go buy a haynes repair manual if you havent already done so and look at the wiring schematic. Look for the vtec soleniod, vtec pressure switch, knock sensor, and oil pressure switch. I had to buy a p13 ecu and grab the required wires from the h22 wire harness. The engine will drop right in. A friend and I alone took the engine out using a cherry picker, and the next day 2 friends and I put the h22 into the car in about 2 hours. The only thing that you will need to transfer over depending on whether ur h22 is jdm or not will be the fuel rail. JDM = right hand drive, fuel filter is on the left and so on and so forth. Also the jdm h22's dizzy is an internal coil were as the usdm h22's dizzy is external, there is a simple wire cut that will solve that issue, i dont remember wat wires they were but if you look around on the forums you will find it. Good luck and let me know how it goes.
  3. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    well this thread is a year old so i hope he got it going by now
  4. execrashnburnexe
    execrashnburnexe New Member
    the obd is different according to http://hondaswap.com/reference-materials/honda-ecu-list-29129/
    im kinda new to this so i may be wrong,
    i might be doing the same swap with my 95 S prelude , Ive also read that ill need to buy a bigger radiator, can anyone confirm? im planning on just using the auto tranny that came with the car
  5. BrutalB83
    Rochester Hills, MI
    Did you miss the part where this thread is six months old?
  6. execrashnburnexe
    its accually older but im doing the same swap and since he was wrong about the obd im wondering what else is needed to do the swap, im thinking hes doing the f22a vtec and i have a f22a non vtec
  7. pre92ludejs
    pre92ludejs New Member
    Loveland, CO
    Have a question.. I have a 92 prelude with the f22. Want to do a h22 swap. How do i modify to run the external coil on the distributor? Also any other tips on issues that i will run into? I know i will need to modify the exhaust down pipe, change over fuel rails, wire for v-tec, i've also heard of modifying the auto tensioner on the timing belt. Any thoughts? Thanks.
