f22 into crx
Discussion in 'HYBRID -> ED-EF / DA' started by d16z6si, Oct 17, 2009.
  1. d16z6si
    d16z6si New Member
    Ok so i have always been a sohc person. I have had my share dual cams, and love surprising people with off the wall crazy built sohc. So this one is a new swap for me. If anyone has any help i really need all that i can get. Thanks A lot:(
  2. c-rex-beat
    c-rex-beat yeah, it's a vtec.
    tyler, TX
    I have thought about this swap before but more like a frankenstein motor build. could be done fairly cheap. theres a mount for it so why not right.
  3. riceracerex
    riceracerex D-Series Ninja
    Pryor, Ok
    How many aftermarket parts are there for a f22? Ever heard of the infamous G23 Frankenstein Build?
  4. SwapShopRacing
    SwapShopRacing Member
    650n Barranca ave #a Covina, Ca 91723 (626) 261-4
    It's basically the same as doing an H22A swap... Mounts, Axles, etc... Unless you are using the Prelude version though you will have to use SOHC Prelude post bracket. Personally I think it's a lot of work for what you are going to get out of it but people will defiantly be surprised when you pop your hood.
    88-91 Honda Civic/ CRX EF H-Series Swap, DIY
  5. d16z6si
    d16z6si New Member
    ok so im going to do this all myself what axels do i need to run i have the accord but its smashed so what all should i use is the ? i guess
  6. c-rex-beat
    tyler, TX
  7. d16z6si
    d16z6si New Member
    non vtech accord
  8. philyphreak2127
    philyphreak2127 Back in the Game
    Littleton, co
    What motor exactly? You could swap on a couple different heads to increase power a bit. f22b2, f23a1, maybe even the non vtec f22a4 head, I have seen people run h23 heads on the f22 blocks as well but if you wanna stick with sohc I would go with the b2 probably. But either way I am glad to see another sohc guy sticking to them. I debated on a b18 swap in my civic when I blew my motor but ended up buildin a mini me instead.
  9. riceracerex
    Pryor, Ok
    SOHC's are going a long ways these days. Speed Factory just ran a 10-second D16y8 with a bad trans and stock cam. Using a nasty 600+ HP Vitara Setup. If they would change the gears and introduce a cam they would easily break into 9's.
  10. 92stoccord
    92stoccord Big Member VIP
    Salem, Ohio
    I wanted to swap an H22 for a while, but when I realized that I could put just as much power down with a good turbo and tune, I figured I'd stick with the f22 and rebuild if I have to, but then I remembered I have no money, and decided to drive it till it dies. F22 would be pretty cool. Built SOHC is always respectable. Good luck!
  11. SwapShopRacing
    I recommend using an H22A half shaft and H22A EF swap axles if you can.
  12. kidkg24
    kidkg24 New Member
    west
    good luck with this, and keep everyone posted. sohc is the new B.lol..
    Old school builds like single cams will always atay freash.
  13. kidkg24
    kidkg24 New Member
    west
    lol. Stay fresh.. damn i'm retarded
  14. riceracerex
    Pryor, Ok
    :lolhammer: Welcome to Honda Swap
  15. d16z6si
    d16z6si New Member
    ok sorry i could not post anything yesterday my computer took a shit im not really to sure what the motor is for sure the car is sitting at my buddies shop and i guess my little rex got nominated for the swap so i need h22 axels and half shaft for an ef i heard from some where the the b18 axels will work is this true or is someone full of shit
  16. TurboRex90
    TurboRex90 Golden EG
    Maryland
    I see good 'ol SwapSwap poped in on this thread.
    Love your guys products :D
    But, glad your sticking with a SOHC. :D
    Pics when it starts !?
  17. d16z6si
    d16z6si New Member
    i will deff have pics up as soon as i start on the swap im takein it to my buddies shop on wendsday :) so excited im just doing stock si right now till i have everything for the f22 plus i wat to do complete rebuild and bore and head work you know all the works before it gets put in
  18. d16z6si
    d16z6si New Member
    ok so i went to jis shop today the motor is an f22b2 out of a 96 acord
