F22 swap 88 civic
Discussion in 'Engine Building' started by Barnsy, Apr 9, 2008.
  1. Barnsy
    Barnsy New Member
    hey what do you think about a f22 swap into an 88 civic?
  2. BrutalB83
    Rochester Hills, MI
    I think you should do some research on it first and then ask a more specific question...
  3. Barnsy
    Barnsy New Member
    ok is it even possible or have you ever heard of this swap before?
  4. BrutalB83
    Rochester Hills, MI
    Yes, it is very much possible. It's done exactly the same as an H22 swap into your chassis, so read up on that for the specifics. Honestly I don't think it's worth it though. It's not a bolt-in kind of swap. You'd have to do some fabricating and buy expensive custom engine mounts. Also, it's a tight fit into the engine bay and it will add some weight to the front of your car. It's not really a daily-driver friendly type of thing.
    If you're going to go through all of that trouble I'd at least do an H22 instead. Unless you're getting the motor for free and you can fabricate, I'd say it's not worth your time...
  5. Barnsy
    Barnsy New Member
    ok its because i rolled the accord and have the motor already but i am not going to spend that much time what is the biggest size motor that is bolt in ? i am trying to get max horsepower free breathing.
  6. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    with out motor mounts..d16y8
  7. Barnsy
    Barnsy New Member
    ok how about with a kit? is a b16 a good idea ?
  8. AHHVTEC
    Alabama
    just depends on what you want power wise
  9. Barnsy
    Barnsy New Member
    enough to make it a threat to muscle cars
  10. Barnsy
    Barnsy New Member
    in the 1/4 mile or on the street
  11. AHHVTEC
    Alabama
    better go with a b18c
  12. BrutalB83
    Rochester Hills, MI
    :werd:
    Or you could boost your stock D and make some decent power...
  13. Barnsy
    Barnsy New Member
    yeah but it needs a rebuild really bad and i dont want to spend the money on the peice of shit
  14. BrutalB83
    Rochester Hills, MI
    You could swap in a newer one and boost. D-series engines are cheap as hell. Check out your local Craigslist, you can probably find at least one for sale...
