f22a swap problems
Discussion in 'HYBRID -> ED-EF / DA' started by mikesleepercivic, Feb 17, 2010.
  1. mikesleepercivic
    mikesleepercivic New Member
    colorado
    what i have is a 1991 civic dx that i swaped in a f22a turbo motor. i have the motor in, it runs, but it throws a code 9 #1 cyp sensor i have tried another distributor same thing. so i decieded to wire in the distributor strait to the ecu same thing. im runin a po6 ecu tuned with neptune. as far as the injectors they are wired strait into the ecu as well. i have an obdo to obd1 conversion for the ecu. the engine harness is the dx harness just modified to fuel injected. i have checked the timing just to make sure it was on and it was. so my questoin is there any thing that mabe i missed or do i need another distributor?
