F22a to H22a Vetch Help please
Discussion in 'Accord' started by Pozidriv1105, Dec 1, 2016.
  1. Pozidriv1105
    Pozidriv1105 New Member
    This is for my husband. We have a 93 manual transmission accord. We are going from OBD1 to OBD2 vetch. Needs some info on the wiring. We have wiring harness, the motor is in and all we need is a couple parts and we are stuck at that point. The fuse and wiring converter for the motors. If someone would be willing shoot him and email that would be helpful. pozidriv1105@Yahoo.com. Thanks buchies.
    OK here's the more detailed info on it:
    93 HONDA ACCORD had a single f22a going with a 97 prelude h22a4 with a h22a head. I have the whole wiring harness computer and setup for the h22. I have the jumper from the obd1 to the obd2. needing to figure out how to rig the Vtec. Any suggestions??????
  2. dilbeckskate
    dilbeckskate infamous
    Kennesaw Ga
    Run the wires to ecu yourself
  3. Pozidriv1105
    Would that be the only option?
  4. dilbeckskate
    Kennesaw Ga
    Easiest... or get the correct obd1 h22 harness and run it obd1 with obd1 electronics... its not hard to do either way
