F22a Tranny on F22b
Discussion in 'Accord' started by Black Ty 1.5, Feb 16, 2007.
  1. Black Ty 1.5
    Black Ty 1.5 New Member
    Brampton,Ontario
    i was jus wondern if a F22a Tranny will bolt onto a F22b engine
  2. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    yes
  3. Black Ty 1.5
    Brampton,Ontario
    running a f22b ecu also huh
  4. Nickg4c
    Nickg4c Member
    Gilbert, Az
    Automatic? Even if it is I don't think it matters.
  5. Black Ty 1.5
    Brampton,Ontario
    naw 5 speed so i cud use the f22a 5pseed ecu
  6. BrutalB83
    Rochester Hills, MI
    It depends on which F22b you're talking about. If it's the VTEC version, then you'll want a 5-speed VTEC ecu. If it's not, then the F22a ecu should be fine.
    I think you said it was the F22b1, which is the VTEC version I believe. If that's the case then you'll want a 5-speed ecu for that particular motor, or you'll want to convert your automatic ecu to manual.
  7. sailor77
    sailor77 New Member
    run that by me again. if I use the non vtec jdm, and the f22a tranny (auto) I need a new ecm? What about the F22b, with F22b tranny and F22a ecu?
  8. AHHVTEC
    Alabama
    dont worrie about the ecu it dont mater what ecu you run as long as the ecu matches the motor
  9. Nickg4c
    Nickg4c Member
    Gilbert, Az
    Wait, did you change motors or just the transmission?
    Tell us exactly what motor and transmission you have and that'll simplify it.
  10. Black Ty 1.5
    Brampton,Ontario
    ok its the f22b motor and i wanna match it up with a f22a tranny that means i could use the the same ecu with no problems if it doesnt have vtec
  11. sailor77
    sailor77 New Member
    Does the ecu have to be changed when going from a F22a to a F22b with or with out tranny swap
  12. AHHVTEC
    Alabama
    just match the ecu to the motor and it will be fine
  13. BrutalB83
    Rochester Hills, MI
    There are different versions of that motor. There's the F22B1, which is a single cam, VTEC-equipped motor, there's the F22B2, which is very similar, but no VTEC, and there's also a JDM dual-cam version, very similar to the US-spec H23.
    If you have the VTEC single cam then you'll need a VTEC ecu. If it's the non-VTEC version then the F22A ecu will probably be ok.
  14. Black Ty 1.5
    Brampton,Ontario
    ok thanks guys u've been very helpfull
