f22a6 swap
Discussion in 'Integra' started by 01 integ type r, Aug 13, 2008.
  1. 01 integ type r
    01 integ type r New Member
    ok i jus bought a 01 integra type r with no motor or tranny i need to kno if its possible to put a f22a6 in temperarly for i can save up for a B18C5
  2. 01 integ type r
    and if the bolt patterns are the same
  3. BrutalB83
    Rochester Hills, MI
    The bolt patterns are not the same at all. I would highly recommend AGAINST the F22 as a temporary fix. It's essentially like installing an H22 into a Civic or Integra, and by that I mean it's not a bolt-in swap. You have to use after-market mounts and cut the transmissions tunnel in order to make the F22 gearbox fit.
    For a temporary motor I'd look towards an LS. That's a complete bolt-in swap. Either that, or just leave it motor-less until you can afford a new B18C5...
