F22B and F23 transmission?
Discussion in 'Accord' started by thekingofvtec, Jul 30, 2009.
  1. thekingofvtec
    thekingofvtec New Member
    I'm doing a auto to manual swap on my 97 Accord, which is a F22B1. I found a 5Speed Manual transmission out of a 2000 Accord Coupe which I think is a F23, possibly mistaken. Would this this transmission even fit a F22B1, and if so, how different are the gear ratios? Maybe better to stick to the to the 97 5Speed...
    Help!
  2. BrutalB83
    Rochester Hills, MI
    The transmission should fit fine, and the gear ratios shouldn't really be that different, as the motors they're attached to aren't that different. I don't have exact gear ratio specs for you, sorry...
  3. thekingofvtec
    okay thanks. another thing. gear ratios, would you happen to know if this gear ratio difference is beeter or worse?
  4. Hondadude141
    TX
    the gears in the F23 tranny are a tad bit longer than the f22's, so me personally I would stick with the 96-97 f22bx tranny
