f22b dohc into my 95 civic
Discussion in 'Civic and del Sol - EG and EK' started by zap45, Apr 19, 2008.
  1. zap45
    zap45 New Member
    albuquerque nm
    im getting ready to swap a f22b dohc(h23) engine in my 95 civic dx.
    My question is what type of exhaust i can use do i have to go custom or can will the stock exhaust bolt up?
    thanks
  2. BrutalB83
    Rochester Hills, MI
    I very much doubt that the stock exhaust will bolt up to an H23. You wouldn't want to use it on an H23 anyway. I'd upgrade to the 2.25"-"2.5" range.
    Are you doing the swap yourself? If not (or even if you are), then I'd probably just take it to a reputable exhaust shop and have them fab something up for you...
  3. zap45
    zap45 New Member
    albuquerque nm
    well me and two other people are doing it. and i like to go with a 2.5
    i also bought the header and downpipe. Do i go custom after that?
  4. BrutalB83
    Rochester Hills, MI
    That is correct. Well, you'll need to either get an appropriate sized cat converter or just delete the cat and have your exhaust flanged to bolt up right to the header down-pipe...
  5. zap45
    zap45 New Member
    albuquerque nm
    ok on this swap the o2 sensor insert is located on the down pipe do i have relocate my o2 sensor
  6. BrutalB83
    Rochester Hills, MI
    Where is the O2 sensor located on the stock motor? Moving it is not really a big deal, you'll just need a short piece of extension wire...
  7. zap45
    zap45 New Member
    albuquerque nm
    well i motor is an f22b(h23) i did not see it on the stock exhaust manifold
    the only place i saw it was on the aftermarket downpipe that i purchase
