F22b1 built w/ Turbo / ecu / exhaust
Discussion in 'Parts: For Sale/Trade/Wanted' started by boostedf22, Dec 26, 2007.
  1. boostedf22
    boostedf22 dis is why im not
    in the land of OZ
    Great swap for a 90-97 accord!!!!!! Or a civic hatch, integra. What ever you want to put it in.
    JDM F22B block-
    Darton Mid Sleeves
    Crower I-beam billet rods
    ACL Bearings
    Wiseco 9:2.1 pistons and rings
    Block was decked
    Head-
    All stock internals
    550 RC injectors
    GM 3bar MAP Sensor
    H22 62mm Throttle Body - port matched.
    All new gaskets and seals and bearings
    Block has around 7k miles on it, and the head has about 5k miles with new seals and around 60-70k on internals.
    Transmission-
    97 accord
    Only has 22k miles - was taken apart and inspected before installation. Was just installed a week ago.
    ACT heavy duty pressure plate w/ 6 puck racing disk
    8.8lbs Fidenza flywheel.
    Turbo-
    Turbonetics T3/T4 .57trim- turbo with 7k miles and been well taken care off.
    HKS BOV
    Tial Wastegate 38mm w/ 9 psi spring
    28x8x2.5 FMIC
    Charge piping for a 94-97 Honda Accord
    F22 log manifold
    2.5 inch dowpipe
    Also included is a 2.5 inch test pipe w/ 2.5inch Apexi N1 catback exhaust.
    ECU-
    P28 socketed ECU street tuned on Crome @ 7psi.(Tuning done by Matt Shue) I also have a S100 chip that was tuned on 14psi that was not a great tune. The S100 chip needs to be retuned.
    This motor does not burn nor leak any fluid. It gets its oil changed about every 1500-1700 miles. The motor has no knocking nor any noises. Runs great, pulls strong.
    The motor is still in the car so a test ride is very possible for serious inquiries.
    Make an offer !!
    Some are old pics so I will update tomorrow. There is alot of stainless braided on it, such as the throttle cable, clutch flex line, radiator hose, ect. ect.ect.
  2. JDM92Lude
    JDM92Lude Banned
    Mechanicsburg, PA
    hey you wouldnt wana sell that downpipe would ya? i need one....and how much you want for the whole setup?
  3. boostedf22
    in the land of OZ
    I'm not parting it out. Trying to sell as a whole.
    6k OBO for everything.
  4. boostedf22
    in the land of OZ
  5. tofasttoslowforyou
    tofasttoslowforyou New Member
    I could not see it going for 4k but why are you selling it?
  6. boostedf22
    in the land of OZ
    OK, figure it like this.
    JDM F22B- 500.00
    F22B transmission- 22k miles 600.00
    Darton Mid Sleeve- 1500.00 installed.
    Crower billet I-beams- 700.00
    Wiseco pistons- 500.00
    ACL Bearings - 100.00
    All new belt, seals gaskets, ect- 250.00
    Turbonetics T3T4 kit- 1500.00
    injectors-200
    gm 3bar map-100
    h22 tb-50
    clutch-300
    flywheel-150
    exhaust-200
    ecu-200
    the tune is bad ass- 500 but lets not count that nor any labor. Plus I have all receipts for everything!! Also there is more on the motor like a 100.00 engine damper, 70.00 braided throttle cable, 60.00 clutch braided cable. and the list goes on.
    If I cant get what I want then I will keep it and buy a hatch or an integra to put it in.
    The only reason I am willing to sell it is because, well I really don't have one. Other than maybe wanting to build something else. But my mind changes weekly.
  7. boostedf22
    in the land of OZ
