f22b1 swap
Discussion in 'HYBRID -> EG-EK / DC' started by wlp2008, Jan 21, 2010.
  1. wlp2008
    wlp2008 New Member
    Dub-Vee
    yea i have a spare f22b1 motor tranny ecu harness dizzy ect ect..
    i was wanting to know what axles would work if i were to do the swap into a 95 4 door integra. the only thing i would need to buy is the chassis and the axles and the mounts. i know fitment could be an issue but its nothing im needing soon so i could beat on the bay for a while..
  2. phunky.buddha
    Dallas / Fort Worth, TX
    If you can get an Integra that still has its transmission in it, get an H to B conversion kit and use all the stock transmission / shifter / axle hardware. You can reuse all the mounts but one also- just fab up a new driver's side mount and you're good to go.
  3. wlp2008
    wlp2008 New Member
    Dub-Vee
    the teg im looking at has no motor/tran. its an 95 4 door. was auto converted to 5-speed. my f22 tranny is auto. i found some mounts for like 230 on some site. but i dunno about the axles.. axles and mounts would defiantly be cheaper then f2b.
    will axles from the teg work. if not which year/model, honda/acura axles could i swap in to work?
  4. phunky.buddha
    Not sure... HASport likes to sell custom axles for an H conversion. I don't know which off the shelf axles work with an H/F swap into an Integra. F2B kits are only about $500-600, which is about where you'd end up if you had to get custom axles (again, not sure if you do) and mounts. Since you don't have an extra B transmission though, it doesn't matter.
  5. BrutalB83
    Rochester Hills, MI
    Are you wanting to put that auto tranny into it? That seems like a dumb idea if it's already set up for manual...
  6. wlp2008
    wlp2008 New Member
    Dub-Vee
    well if i had an extra manual tranny i would do that instead.. but im working with what i got..
    the car is not going to be for me.. im either going to resale the car or give it to a family member. the car needs a valvetrain to my knowledge it came stock as a auto was conveterd to 5-speed and then all the motor and tranny was taken out of it..
    i just need an answer to what axles will work with a f/h motor and tranny into the 95 integra.
