Does anyone know what transmission(s) would be a direct fit for my f22b1 automatic? I've heard H23 will work, but when I talked to a salvage yard this dude insisted that I would have to change the ECU. My understanding is that you can just swap the TCU at worst and it will run fine. Tiger Japanese has one for the 90-93, and I don't know if it would work either. SO, I guess my big questions are: 1) When changing from one transmission to another, does the ECU and or harness need swapped? 2) What transmission would be ideal for this car, if I can't find a cheap tranny? 3) If I could get a good enough deal on all the parts, I could convert to manual, is that swap totally not worth the effort? 4) Is a rebuild something you can DIY on, if you have worked on everything else Honda with ease? It's just slipping, I haven't let it blow out and completely ruin anything inside yet, if that's worth anything... 5) Anyone have any links to cheap transmissions and rebuild kits? Thanks in advance.
