F22B2 and F22A4
Discussion in 'Accord' started by mes, May 1, 2010.
  1. mes
    mes New Member
    Hey Guys, i got 2 engines- F22B2 from a 1994 accord, and a A4 from a 1991 Accord- and i don't know what to do with them. How could i get more power out of both of them.
  2. f22b1 coupe
    f22b1 coupe Junior Member
    Indiana
    Depends on what kind of money you have. Especially if you are going to run them hard though, replace the timing belt, water pump, and oil seals while they aren't in a car, much easier to do on the ground. As for power, learn the basics of auto performance, google it. More air and fuel in, more air out. In an ideal world you want to get a cold air intake, larger throttle body, high flow intake manifold, performance camshaft, header, and high flow exhaust system. You can reprogram the ECU to match performance mods and get even more power. Or, you can boost it with a turbo, but that's very involved.
    In reality, just get on ebay, buy a cheap cold air intake, header, and muffler. That's how you can pick up the most power for $200 or so.
  3. mes
    mes New Member
    not what i meant but ok. what i really meant was can i mix n match the to eengines like ppl do with the A4 n A6 to get more power? i know about auto performance.
  4. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    the best power would to be leave it alone and just use the 94 accord motor
  5. mes
    mes New Member
    so then what am i to do with the A4 from the 1990?
  6. AHHVTEC
    Alabama
    keep it for a spare get rid of it or whatever
  7. BrutalB83
    Rochester Hills, MI
    Sell it to someone who wants an A4. I don't see why this is so difficult. There's no huge advantage to mixing and matching parts from these two engines. Just decide which one you want to keep and sell the other...
