F23 Into 1990 Accord
Discussion in 'HYBRID -> BA-BB /CA-CD' started by 90accord, Mar 2, 2003.
  1. 90accord
    90accord Junior Member
    I was wondering how much work is involved in swapping a 1998 and up f23 accord motor into a 1990 accord lx. I have access to a f23, and the ecu, but will i need the ecu?, if so will it work with my car.
  2. dohcvtec_accord
    dohcvtec_accord WRX Sellout
    The left lane
    Yes, you'll need the ECU, and you'll need to convert from OBD0 to OBD2. I have no idea what's involved with that sort of wiring. Hopefully someone else here could help you out with that.
  3. 90accord
    thanks for the info, to switch from obd0 to obd2 is it only the wire harness or more?
  4. ebisu8
    ebisu8 Junior Member
    hey the swap is simple. i did an f23a1 into a 94 accord. everything bolts right in. on my car i used the 94 accord ex ecu that i got at a junkyard. i had to add a knock sensor, vtec, and some other wire. i cant remember. but ya i just finished it in january. we pulled and installed the engine and tranny in like two days. and the wiring took a week. so it wasnt hard at all.
  5. dohcvtec_accord
    The left lane
    Yeah but yours was OBD1, it's a little different.
    Also, if you really used an ECU from a 94 EX, you didn't need to wire for the knock sensor. That ECU doesn't look for a knock sensor.
